Zum Hauptinhalt wechseln
Samsung BD-E5400 Wi-Fi Card Replacement
Was du brauchst
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: Schritt 1, Bild 1 von 2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: Schritt 1, Bild 2 von 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: Schritt 3, Bild 1 von 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: Schritt 3, Bild 2 von 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: Schritt 3, Bild 3 von 3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
Abschluss
IUPUI, Team S1-G3, Arle Fall 2018 Mitglied von IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 282
