Einleitung
A guide on how to replace a damaged DC power board on a Samsung BD-7500.
Was du brauchst
Remove the three 10mm screws with a Phillips #0 screwdriver.
Pry the top off with a plastic opening tool.
Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
Remove the 7mm screw with a Phillips #1 screwdriver.
Grip the blue tab attached to the base and pull upwards.
Fast fertig!
Abschluss
