Einleitung
In this guide, you will learn how to replace or remove the power cord to a Samsung BD-F5700 Blu-Ray player. You will see step-by-step how to open the device, which screws to remove, and how to ultimately remove the power cord from the device. This repair would be needed if your device is no longer getting power to it. Always make sure the device is unplugged before beginning to work on it, as there is a chance of shock from exposed wiring.
Was du brauchst
Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
Remove plastic cover from board.
Pull upward on back of the black and white wire to dislocate the black tab piece from device.
To remove the cord from the device entirely, press on the white tab in the device and gently pull.
Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
Pull the tab off the wire so that it can be placed on the replacement cord.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
