Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Is your Blu-ray player not able to play your favorite flicks due to a faulty disc drive? If so, all you need is a #1 Phillips screwdriver and this guide to show how to replace the DVD disc tray with a new one.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  5. Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
    • Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
  6. Push two small prongs on either side of disc tray inwards and push disc tray forward.
    • Push two small prongs on either side of disc tray inwards and push disc tray forward.
  7. Remove disc tray
    • Remove disc tray
Abschluss
Louis McKean
501 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G21, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 15
Insgesamt: 384
