Einleitung
In the event of a catastrophic failure on your Blu-ray player, the Main Logic Board may have failed. This guide is for replacing a damaged or broken Main Logic Board. The only tool required is a #1 Phillips head screwdriver.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
Tilt the board forward and lift up to remove from the chassis.
Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
Also remove the 10 mm screw from the rear panel.
Remove the Main Logic Board
