Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In the event of a catastrophic failure on your Blu-ray player, the Main Logic Board may have failed. This guide is for replacing a damaged or broken Main Logic Board. The only tool required is a #1 Phillips head screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover. Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  6. Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board. Pry a little bit on each side of board until the board lifts away. Tilt the board forward and lift up to remove from the chassis.
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
  7. Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  8. Disconnect the WiFi board cable connector
    • Disconnect the WiFi board cable connector
  9. Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board Also remove the 10 mm screw from the rear panel.
    • Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
    • Also remove the 10 mm screw from the rear panel.
    • Remove the Main Logic Board
Abschluss
Louis McKean
501 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G21, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 212
