Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If there are any issues connecting to the WiFi with the device that can not seem to fixed, this simple guide explains how to replace the module. The only tool required is a #1 Phillips head screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Disconnect the WiFi board cable connector from the main logic board
    • Disconnect the WiFi board cable connector from the main logic board
  5. Using a #1 Phillips head screwdriver, remove the 7.5 mm screw.
    • Using a #1 Phillips head screwdriver, remove the 7.5 mm screw.
    • Slightly tilt the WiFi module sideways to remove from chassis.
Abschluss
Louis McKean
501 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G21, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 112
