Einleitung
This guide will show how to remove and replace the disk reader in the case that it is no longer reading the DVDs.
Was du brauchst
Use the Phillips Head #2 screwdriver to remove the three 10 mm screws on the back panel.
Remove the two 7.5 mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
Push two small prongs on both sides inwards and push forward.
Remove the disk tray.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
