Zum Hauptinhalt wechseln
Samsung BD-H5100 Motherboard Replacement
Was du brauchst
  1. Samsung BD-H5100 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung BD-H5100 Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung BD-H5100 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Motherboard Replacement: Schritt 3, Bild 1 von 2 Samsung BD-H5100 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung BD-H5100 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Motherboard Replacement: Schritt 6, Bild 1 von 2 Samsung BD-H5100 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
    • Remove the black cover.
  7. Samsung BD-H5100 Motherboard Replacement: Schritt 7, Bild 1 von 2 Samsung BD-H5100 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Pinch the white clip and pull straight up on the power cord.
    • Remove the power cord.
  8. Samsung BD-H5100 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips Head #2 to remove the 7.5mm screw.
  9. Samsung BD-H5100 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Use your finger to pry the metal tab slightly up.
    • This may break after several uses.
  10. Samsung BD-H5100 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Slide out the Motherboard.
    • Be careful when touching the bottom because it is sharp.
Abschluss
Mira Patel
580 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-2, Leahy Fall 2016 Mitglied von USF Tampa, Team 1-2, Leahy Fall 2016
USFT-LEAHY-F16S1G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 520
