Einleitung
This guide will show how to replace the Motherboard.
Was du brauchst
Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
Push two small prongs on both sides inwards and push forward.
Remove the disk tray.
Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
Remove the black cover.
Pinch the white clip and pull straight up on the power cord.
Remove the power cord.
