Einleitung
Use this guide to replace the motherboard.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Use the spudger to remove the rubber stoppers from the top of the cover. Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  2. Use the spudger to loosen and separate the front and back covers. Pick up the back cover once loosened. The front and back covers will be attached to each other by a gold wire.
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  3. Use the screwdriver to unscrew the four screws that hold the scroll wheel in place. Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board. Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
  6. Use the spudger to unsnap the black rectangular connection from the motherboard. Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  7. Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing. Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  8. Once all of the connections have been snapped off of the motherboard, the motherboard can be removed. Lift up on the motherboard and it will come free of the front casing.
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
Abschluss
Kristin Manna
17 Reputation
10 Anleitungen geschrieben
Clemson, Team 14-4, Benson Fall 2012 Mitglied von Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Mitglieder
12 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 392
