Zum Hauptinhalt wechseln
Samsung Blast Back Cover Replacement
Was du brauchst
  1. Samsung Blast Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Joseph
129 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 173
