1. Your phone should look like this before disassembly. Your phone should look like this before disassembly.
    • Your phone should look like this before disassembly.
  2. Remove the battery cover by sliding the back panel up. This will expose the battery. Remove the battery cover by sliding the back panel up. This will expose the battery.
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Lift up the top portion of the battery and pull it out.
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Du bist ein Genie!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  5. Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case. The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
      • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
      • Note the positions of button pads for reassembly.
  6. Remove the buttons for the camera and volume. Remove the buttons for the camera and volume.
    • Remove the buttons for the camera and volume.
  7. Use a prying tool to detach the motherboard from main body. Carefully detach the motherboard from the two connectors. You could also use a pry tool for the second step.
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
      • You could also use a pry tool for the second step.
      • Be careful with the motherboard as not to scrape or damage its components.
  8. Slide the keyboard straight up to free it from its alignment pins. Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
    • Slide the keyboard straight up to free it from its alignment pins.
      • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Abschluss
Jordan Taylor
1 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-5, Buehl Spring 2014 Mitglied von Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Mitglieder
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 194
