Einleitung
Use this guide to replace the motherboard of a Samsung Blast. This guide will take you through the process of how to successfully remove and replace the motherboard. A motherboard may need replacement if the device stops working.
Was du brauchst
With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
