Zum Hauptinhalt wechseln
Samsung Brightside Logic board Replacement
Was du brauchst
  1. Samsung Brightside Logic board Replacement, Logic board: Schritt 1, Bild 1 von 3 Samsung Brightside Logic board Replacement, Logic board: Schritt 1, Bild 2 von 3 Samsung Brightside Logic board Replacement, Logic board: Schritt 1, Bild 3 von 3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Logic board Replacement: Schritt 2, Bild 1 von 3 Samsung Brightside Logic board Replacement: Schritt 2, Bild 2 von 3 Samsung Brightside Logic board Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Logic board Replacement: Schritt 3, Bild 1 von 3 Samsung Brightside Logic board Replacement: Schritt 3, Bild 2 von 3 Samsung Brightside Logic board Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Logic board Replacement: Schritt 4, Bild 1 von 3 Samsung Brightside Logic board Replacement: Schritt 4, Bild 2 von 3 Samsung Brightside Logic board Replacement: Schritt 4, Bild 3 von 3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Logic board Replacement: Schritt 5, Bild 1 von 2 Samsung Brightside Logic board Replacement: Schritt 5, Bild 2 von 2
    • Detach the LCD connector.
    • Remove the logic board
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
oldturkey03
782.480 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
544 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 1,516
