Zum Hauptinhalt wechseln
Samsung Brightside Speaker Module Replacement
Was du brauchst
  1. Samsung Brightside Speaker Module Replacement, Speaker Module: Schritt 1, Bild 1 von 3 Samsung Brightside Speaker Module Replacement, Speaker Module: Schritt 1, Bild 2 von 3 Samsung Brightside Speaker Module Replacement, Speaker Module: Schritt 1, Bild 3 von 3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Speaker Module Replacement: Schritt 2, Bild 1 von 3 Samsung Brightside Speaker Module Replacement: Schritt 2, Bild 2 von 3 Samsung Brightside Speaker Module Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Speaker Module Replacement: Schritt 3, Bild 1 von 3 Samsung Brightside Speaker Module Replacement: Schritt 3, Bild 2 von 3 Samsung Brightside Speaker Module Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Speaker Module Replacement: Schritt 4, Bild 1 von 3 Samsung Brightside Speaker Module Replacement: Schritt 4, Bild 2 von 3 Samsung Brightside Speaker Module Replacement: Schritt 4, Bild 3 von 3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Speaker Module Replacement: Schritt 5, Bild 1 von 3 Samsung Brightside Speaker Module Replacement: Schritt 5, Bild 2 von 3 Samsung Brightside Speaker Module Replacement: Schritt 5, Bild 3 von 3
    • Detach the LCD connector.
    • Remove the logic board
    • This is the speaker module. In the center is the camera, but it is not part of the module.
  6. Samsung Brightside Speaker Module Replacement: Schritt 6, Bild 1 von 3 Samsung Brightside Speaker Module Replacement: Schritt 6, Bild 2 von 3 Samsung Brightside Speaker Module Replacement: Schritt 6, Bild 3 von 3
    • turn the logic board over. The speaker module is held in place
    • by one Phillips screw
    • and two clips
    • Remove the Phillips screw.
    • It is a M1X2 Phillips screw
    • Next disengage one of the clips by simply applying some sideways pressure with your fingernail. This will loosen the module.
  7. Samsung Brightside Speaker Module Replacement: Schritt 7, Bild 1 von 2 Samsung Brightside Speaker Module Replacement: Schritt 7, Bild 2 von 2
    • Turn the logic board around. With the speaker module loose, simply lift it off the board.
    • Speaker module removed.
    • Camera
    • and audio jack
    • are not part of this module and will remain on the board.
Abschluss
oldturkey03
783.207 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
549 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 967
