Einleitung
Follow these steps if you are experiencing uneven print quality or lines in your printed documents.
  1. Turn the printer off and wait a few minutes for it to cool.
    • Turn the printer off and wait a few minutes for it to cool.
  2. Pull paper tray out and set aside.
    • Pull paper tray out and set aside.
  3. Open the front cover. Open the front cover.
    • Open the front cover.
  4. Pull the waste toner container out of the printer using the handle.
    • Pull the waste toner container out of the printer using the handle.
    • Make sure to keep waste toner container upright to avoid spillage.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Pull the imaging unit out of the printer using bottom handle. Use green handle on top of imaging unit to steady unit as you pull it out. At this point you can set the printer aside as you will only need the imaging unit to continue repair.
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • At this point you can set the printer aside as you will only need the imaging unit to continue repair.
  7. Remove these two screws. Do not expose imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • Remove these two screws.
    • Do not expose imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
  8. Carefully pry plastic arm away from main unit.
    • Carefully pry plastic arm away from main unit.
  9. Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left. When removing the organic photo conductor take care to not lose the small spring on the back left. At this point you may want to put on plastic gloves to keep from staining hands with printer ink.
    • Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left.
    • When removing the organic photo conductor take care to not lose the small spring on the back left.
    • At this point you may want to put on plastic gloves to keep from staining hands with printer ink.
  10. Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit. Keep toner rollers level to avoid toner spillage.
    • Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit.
    • Keep toner rollers level to avoid toner spillage.
  11. Remove these five screws from the top of the black toner transfer unit. Remove main and smaller z-shaped plates. Remove main and smaller z-shaped plates.
    • Remove these five screws from the top of the black toner transfer unit.
    • Remove main and smaller z-shaped plates.
  12. Remove these three screws from the right end of the toner transfer unit. Remove these three screws from the right end of the toner transfer unit.
    • Remove these three screws from the right end of the toner transfer unit.
  13. Remove plastic end piece.
    • Remove plastic end piece.
    • Gently pull out black toner roller.
    • Insert new roller in place of old roller turning slightly to fit.
    • Be careful not to pinch small foam square when inserting new roller.
    • Cover new roller with toner by rotating roller by hand.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Heather Howard
466 Reputation
4 Anleitungen geschrieben
University of Maine, Team 1-1, Diaz Fall 2014 Mitglied von University of Maine, Team 1-1, Diaz Fall 2014
UMAINE-DIAZ-F14S1G1
3 Mitglieder
I need more information pertaining step 8. In order to separate the parts, in which directions should the be moved first and where is the best point to apply force ?
Bernd Dreyer - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 37
Insgesamt: 1,888
