Zum Hauptinhalt wechseln
Samsung CLP-300 Imaging Unit Replacement
  1. Samsung CLP-300 Imaging Unit Replacement, Imaging Unit: Schritt 1, Bild 1 von 1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Imaging Unit Replacement: Schritt 2, Bild 1 von 2 Samsung CLP-300 Imaging Unit Replacement: Schritt 2, Bild 2 von 2
    • Open the front cover
  3. Samsung CLP-300 Imaging Unit Replacement: Schritt 3, Bild 1 von 1
    • Remove waste toner container from the printer.
  4. Samsung CLP-300 Imaging Unit Replacement: Schritt 4, Bild 1 von 3 Samsung CLP-300 Imaging Unit Replacement: Schritt 4, Bild 2 von 3 Samsung CLP-300 Imaging Unit Replacement: Schritt 4, Bild 3 von 3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
    • Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
    • Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Heather Howard
586 Reputation
4 Anleitungen geschrieben
University of Maine, Team 1-1, Diaz Fall 2014 Mitglied von University of Maine, Team 1-1, Diaz Fall 2014
UMAINE-DIAZ-F14S1G1
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 13,147
