Einleitung
Use this guide to replace your captivates 3.5mm headphone jack.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use a spudger to disconnect the three highlighted connectors.
Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
Gently pull up on the audio jack, taking the attached ribbon cable with it.
7 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
Between steps 7 and 8, there are a number of steps missing, including the removal of the camera, and the removal of the speaker assembly.
These can be found on the "Mother Board" repair manual, back on the device page.
~Desmond
