Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If you receive an error message when attempting to use your camera, and resetting to factory settings did not fix it, then you need to replace the camera or ensure that your camera is connected to the motherboard. At times, if you've dropped your phone, the camera may detach from the motherboard.
  1. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Remove battery with plastic opening tool or finger. Remove battery with plastic opening tool or finger.
    • Remove battery with plastic opening tool or finger.
  3. Remove the seven screws from backplate using the #00 screwdriver. Remove the seven screws from backplate using the #00 screwdriver.
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the back plate using the plastic opening tool. There is a lip on each side, and both must be pried up. You can work your way around the edges after prying the two sides.
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  6. Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone. Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  7. Disconnect the antenna cable from the motherboard using tweezers.
    • Disconnect the antenna cable from the motherboard using tweezers.
  8. Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  9. Lift the motherboard out of the base of the phone. Lift the motherboard out of the base of the phone.
    • Lift the motherboard out of the base of the phone.
  10. Using the opening tool, pry up the camera attachment from the motherboard. Using the opening tool, pry up the camera attachment from the motherboard. Using the opening tool, pry up the camera attachment from the motherboard.
    • Using the opening tool, pry up the camera attachment from the motherboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jessica Martinez
253 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-3, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 460
