Einleitung
How to remove the motherboard of a Samsung Captivate Glide.
Was du brauchst
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Remove the back plate using the plastic opening tool.
There is a lip on each side, and both must be pried up.
Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
