Zum Hauptinhalt wechseln
Samsung Captivate Glide Screen Replacement
Was du brauchst
  1. Samsung Captivate Glide Screen Replacement, Motherboard: Schritt 1, Bild 1 von 3 Samsung Captivate Glide Screen Replacement, Motherboard: Schritt 1, Bild 2 von 3 Samsung Captivate Glide Screen Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Screen Replacement: Schritt 2, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Screen Replacement: Schritt 3, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Screen Replacement: Schritt 4, Bild 1 von 3 Samsung Captivate Glide Screen Replacement: Schritt 4, Bild 2 von 3 Samsung Captivate Glide Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Screen Replacement: Schritt 5, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Screen Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Screen Replacement: Schritt 8, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 8, Bild 2 von 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Screen Replacement, Screen: Schritt 9, Bild 1 von 2 Samsung Captivate Glide Screen Replacement, Screen: Schritt 9, Bild 2 von 2
    • Remove the eight screws with the #00 screwdriver.
  10. Samsung Captivate Glide Screen Replacement: Schritt 10, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 10, Bild 2 von 2
    • Remove blue tape using the tweezers.
  11. Samsung Captivate Glide Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove screws with the #00 screwdriver.
  12. Samsung Captivate Glide Screen Replacement: Schritt 12, Bild 1 von 1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide Screen Replacement: Schritt 13, Bild 1 von 1
    • Lift the back plate.
    • To remove to slide flex cable, gently peel back from the back plate and remove back plate.
  14. Samsung Captivate Glide Screen Replacement: Schritt 14, Bild 1 von 3 Samsung Captivate Glide Screen Replacement: Schritt 14, Bild 2 von 3 Samsung Captivate Glide Screen Replacement: Schritt 14, Bild 3 von 3
    • Slide the flex cable through the slot. Be careful to not tear the cable.
    • Set the front plate down.
  15. Samsung Captivate Glide Screen Replacement: Schritt 15, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 15, Bild 2 von 2
    • Remove the four corner screws using the #00 screwdriver.
  16. Samsung Captivate Glide Screen Replacement: Schritt 16, Bild 1 von 3 Samsung Captivate Glide Screen Replacement: Schritt 16, Bild 2 von 3 Samsung Captivate Glide Screen Replacement: Schritt 16, Bild 3 von 3
    • Using the plastic opening tool, release all the clips on all four sides holding the screen assembly.
    • You can now remove the back plate by sliding the flex cable through the slot.
  17. Samsung Captivate Glide Screen Replacement: Schritt 17, Bild 1 von 3 Samsung Captivate Glide Screen Replacement: Schritt 17, Bild 2 von 3 Samsung Captivate Glide Screen Replacement: Schritt 17, Bild 3 von 3
    • Use the plastic opening tool to release the main jaw connector, front speaker and camera.
  18. Samsung Captivate Glide Screen Replacement: Schritt 18, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 18, Bild 2 von 2
    • By using the plastic opening tool you can release the keypad flex cable from the jaw connecter clamp.
  19. Samsung Captivate Glide Screen Replacement: Schritt 19, Bild 1 von 2 Samsung Captivate Glide Screen Replacement: Schritt 19, Bild 2 von 2
    • Use a heat gun or blow dryer.
    • Heat the outside edges using quick movements for about 45 seconds.
  20. Samsung Captivate Glide Screen Replacement: Schritt 20, Bild 1 von 3 Samsung Captivate Glide Screen Replacement: Schritt 20, Bild 2 von 3 Samsung Captivate Glide Screen Replacement: Schritt 20, Bild 3 von 3
    • Using the plastic opening tool to pry around the edges, release the touch screen from the screen frame.
  21. Samsung Captivate Glide Screen Replacement: Schritt 21, Bild 1 von 3 Samsung Captivate Glide Screen Replacement: Schritt 21, Bild 2 von 3 Samsung Captivate Glide Screen Replacement: Schritt 21, Bild 3 von 3
    • While adhesive is still warm, use the plastic opening tool to gently remove the keyboard flex cable from the screen.
    • You can now replace the screen assembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tyler Moore
139 Reputation
1 Anleitung geschrieben
USF Tampa, Team 5-3, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 970
