Einleitung
How to remove the main speaker of the Samsung Captivate Glide.
  1. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off. Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Remove battery with plastic opening tool or finger. Remove battery with plastic opening tool or finger.
    • Remove battery with plastic opening tool or finger.
  3. Remove the seven screws from backplate using the #00 screwdriver. Remove the seven screws from backplate using the #00 screwdriver.
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Remove the back plate using the plastic opening tool. There is a lip on each side, and both must be pried up. You can work your way around the edges after prying the two sides.
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone. Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  7. Disconnect the antenna cable from the motherboard using tweezers.
    • Disconnect the antenna cable from the motherboard using tweezers.
  8. Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  9. Lift the motherboard out of the base of the phone. Lift the motherboard out of the base of the phone.
    • Lift the motherboard out of the base of the phone.
  10. Using the plastic opening tool, detach the tab connecting the speaker to the motherboard.
    • Using the plastic opening tool, detach the tab connecting the speaker to the motherboard.
  11. Remove speaker manually.
    • Remove speaker manually.
    • There is nothing connecting it to the motherboard, so just pull.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nicholas Mira
280 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-3, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 267
