Einleitung
How to remove the main speaker of the Samsung Captivate Glide.
Was du brauchst
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Remove the back plate using the plastic opening tool.
There is a lip on each side, and both must be pried up.
Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
Disconnect the antenna cable from the motherboard using tweezers.
Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
Using the plastic opening tool, detach the tab connecting the speaker to the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
