Einleitung
Cracked frame? Use this guide to repair your Captivate's rear case.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
12 weitere Nutzer haben diese Anleitung absolviert.
