Einleitung
Issues with battery life and a dead battery can be resolved by following this guide.
Was du brauchst
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
Lift the panel out of the way to reveal the battery.
Using a plastic opening tool, pry the connector up from the contact.
Remove the battery from the device.
