Zum Hauptinhalt wechseln
Samsung Chromebook 2 XE503c12 Daughterboard Replacement
  1. Samsung Chromebook 2 XE503c12 Daughterboard Replacement, Daughterboard: Schritt 1, Bild 1 von 1
    • Turn the power off before beginning this step
    • It is common for Chromebooks to have rubber circle pads covering the four screws on each of the four corners. You can use any opening tool to remove the rubber circle pads.
    • Lay the Chromebook down in a way that the bottom cover faces upward.
    • Remove all nine screws from the back cover using a Phillips #00 screw.
  2. Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 2, Bild 3 von 3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
    • Be gentle while prying to avoid breaking the back cover.
  3. Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 3, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 3, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
  4. Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 4, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 4, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 4, Bild 3 von 3
    • Use a blunt precision tweezer to remove the speaker cord from the daughterboard.
  5. Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 5, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 5, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 5, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove all of the two screws from the daughterboard.
  6. Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 6, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 6, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 6, Bild 3 von 3
    • You must first lift the locking bar of the ZIF connector before removing the ribbon cable.
    • Gently, remove the orange tape by pulling it outward.
    • Using an opening tool, gently pull the daughterboard upward.
  7. Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 7, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 7, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Daughterboard Replacement: Schritt 7, Bild 3 von 3
    • Gently pull the daughterboard away from the Chromebook.
    • Be gentle because the daughterboard might be a little glued.
Abschluss
Nate Duvall
154 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G1, Wilson Summer 2019 Mitglied von IUPUI, Team S1-G1, Wilson Summer 2019
IUPUI-WILSON-SU19S1G1
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 204
