Zum Hauptinhalt wechseln
Samsung Chromebook 2 XE503c12 Screen Replacement
Was du brauchst
  1. Samsung Chromebook 2 XE503c12 Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Chromebook 2 XE503c12 Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 2, Bild 1 von 2 Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 3, Bild 1 von 2 Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 5, Bild 1 von 1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Screen Replacement, Screen: Schritt 6, Bild 1 von 2 Samsung Chromebook 2 XE503c12 Screen Replacement, Screen: Schritt 6, Bild 2 von 2
    • Remove the four 5mm Phillips #0 screws on the hinges.
  7. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 7, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 7, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 7, Bild 3 von 3
    • Unplug two auxiliary wires leading to the top lid.
    • Using the plastic prying tool, lift the hinge on the connector up and pull the connector away.
  8. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 8, Bild 1 von 1
    • Lift the hinges up and separate the top lid from the bottom casing.
  9. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 9, Bild 1 von 3 Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 9, Bild 2 von 3 Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 9, Bild 3 von 3
    • Using the plastic prying tool, carefully pry the casing apart from the screen.
    • When prying case apart, there is a risk of screen and parts of the casing shattering and cutting you.
  10. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the four 5mm Phillips #0 screws holding the screen in place.
  11. Samsung Chromebook 2 XE503c12 Screen Replacement: Schritt 11, Bild 1 von 1
    • Lift and remove the screen from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 417
