Einleitung
Issues with horrible sound quality or bad speakers can be fixed by following this guide.
Was du brauchst
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
Lift the panel out of the way to reveal the battery.
Using a plastic opening tool, pry the connector up from the contact.
Remove the battery from the device.
Remove two 7mm Phillips #0 screws from each speaker.
Pull speakers out of laptop.
