Einleitung
This guide illustrates how to remove the Samsung Chromebook 3 XE500C13-K02US battery. You will need to open the device’s back panel as the battery is located inside the case.
Was du brauchst
Place the laptop back cover facing up to expose the screws.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Use an iFixit opening tool to wedge in between the case and body of the laptop.
Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
2 weitere Personen haben diese Anleitung absolviert.
