Zum Hauptinhalt wechseln
Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement
Was du brauchst
  1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: Schritt 2, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: Schritt 3, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: Schritt 3, Bild 2 von 2
    • Remove the cover exposing the inside of the laptop.
Abschluss
Mick McCarty
980 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 352
