Zum Hauptinhalt wechseln
Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement
Was du brauchst
  1. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: Schritt 1, Bild 2 von 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
  4. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the silver bracket.
  5. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Remove the 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the wire connector from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Remove the black and white wires from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 8, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 8, Bild 2 von 2
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  9. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: Schritt 9, Bild 1 von 1
    • Lift and remove the I/O board from the base of the laptop
Abschluss
Alex
178 Reputation
1 Anleitung geschrieben
IUPUI, Team 3-3, Harley Spring 2023 Mitglied von IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 155
