Einleitung
This guide is a step-by-step guide on how to replace the Samsung Chromebook 3 XE500C13-K02US I/O board with integrated Wi-Fi card. You will need to remove the battery, disconnect the I/O board from the motherboard, remove the 2 pins speaker connecter, and the black and white wire running into the hinge cover
Was du brauchst
Place the laptop back cover facing up to expose all nine 4.6 mm screws.
Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
Wedge a plastic opening tool underneath the cover of the laptop.
Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
Remove the cover of the laptop to expose the inside components.
Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
Lift the clip of the ribbon cable connector.
Remove the ribbon cable from the I/O board.
