Zum Hauptinhalt wechseln
Samsung Chromebook 3 XE500C13-K02US Speakers Replacement
Was du brauchst
  1. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 2, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 3, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 3, Bild 2 von 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 5, Bild 1 von 3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 5, Bild 2 von 3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 5, Bild 3 von 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: Schritt 7, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: Schritt 7, Bild 2 von 2
    • Remove two 4.9mm silver screws with a Phillips #00 screwdriver.
    • Each speaker only has 1 screw.
  8. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 8, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 8, Bild 2 von 2
    • Use the spudger to pry the speaker connector sideways out out of the motherboard.
    • Repeat this step for the left speaker.
  9. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: Schritt 9, Bild 1 von 1
    • Remove the speakers by lifting them upwards and out of the laptop.
Abschluss
Mick McCarty
980 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 300
