Einleitung
This guide demonstrates how to removing the Samsung Chromebook 3 XE500C13-K02US track pad.
Was du brauchst
Place the laptop back cover facing up to expose the screws.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Use an iFixit opening tool to wedge in between the case and body of the laptop.
Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
Remove the ribbon cable by lifting it out of the connector.
Lift the grey adhesive tape.
Lift the track pad from the top.
Slide the track pad away from yourself to clear the black plastic edge.
Lift the track pad up and out of the laptop.
