Zum Hauptinhalt wechseln
Samsung Chromebook 3 XE500C13-K02US Track pad Replacement
Was du brauchst
  1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 2, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 3, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 3, Bild 2 von 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 5, Bild 1 von 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 5, Bild 2 von 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 5, Bild 3 von 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: Schritt 7, Bild 1 von 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: Schritt 7, Bild 2 von 2
    • Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 8, Bild 1 von 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 8, Bild 2 von 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 8, Bild 3 von 3
    • Remove the ribbon cable by lifting it out of the connector.
    • Lift the grey adhesive tape.
  9. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 9, Bild 1 von 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 9, Bild 2 von 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: Schritt 9, Bild 3 von 3
    • Lift the track pad from the top.
    • Slide the track pad away from yourself to clear the black plastic edge.
    • Lift the track pad up and out of the laptop.
Abschluss
Mick McCarty
980 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 279
