Einleitung
This guide will explain the steps to replace your Samsung Chromebook 3 speakers. You will start by removing the bottom case.
Was du brauchst
Place the Chromebook face down so the bottom case is uncovered.
Use the Phillips #00 screwdriver to remove all nine 4.6mm screws from the back case.
Use a nylon spudger or plastic opening tool to pry the case up from the vent on the hinge side of the Chromebook.
Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
Use a spudger to gently push the cable connector sideways from the motherboard and the left speaker to disconnect the cable.
Remove the speaker.
Use a spudger to gently push the cable connector sideways from the motherboard and the right speaker to disconnect the cable.
Remove the speaker.
