Was du brauchst
Face hinge side towards you
Unscrew three 4.55mm Philips #000 screws (pointed by the arrow heads) from the each of left and right hinges
Pull out the black film connected to the motherboard in the white slot
Open up chromebook hold onto the hinges as you open to make it easier
Separate the keyboard and screen and put the keyboard off to the side
Use the ifixit opening tool to pop the outer edge of the scree up
Remove the four 3mm Phillips #000 screws
Lift the screen up slowly
Find the black wire on the back and lift the metal clamp
Pull the black film to remove the wire
Remove the three 2.8 mm screws marked by arrows from both the left and right hinges
Lift the hinges
