Was du brauchst
Hold down the power button until the device powers off
Close the device and flip it over
Remove the four rubber sockets near the corners of the device
Then remove the four 4.6 mm Phillips #00 screws
Use the metal spudger to pop the back off. Near the hinges is typically an easier place to start.
Continue along the edges until the back is completely detached.
Locate the long grey box with the black band, which is labeled "Laptop Battery."
Remove the gray piece labeled "bracket battery BA61 - 03983A" located over the golden band connecting the battery and motherboard by unscrewing the two 4 mm Phillips #00 screws
Unplug the golden band coming from the battery to the motherboard.
Using the Philips #000 remove the four 4mm screws holding the battery in place.
Face hinge side towards you
Unscrew three 4.55mm Philips #000 screws (pointed by the arrow heads) from the each of left and right hinges
Pull out the black film connected to the motherboard in the white slot
Open up chromebook hold onto the hinges as you open to make it easier
Separate the keyboard and screen and put the keyboard off to the side
Use the ifixit opening tool to pop the outer edge of the scree up
Remove the four 3mm Phillips #000 screws
Lift the screen up slowly
Find the black wire on the back and lift the metal clamp
Pull the black film to remove the wire
Eine weitere Person hat diese Anleitung absolviert.
