Zum Hauptinhalt wechseln
Samsung Chromebook Plus Battery Replacement
Was du brauchst
  1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: Schritt 1, Bild 1 von 1
    • Remove the 8 PHILIPS#0 screws
  2. Samsung Chromebook Plus Battery Replacement, Removing back panel: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: Schritt 3, Bild 1 von 1
    • Use your PHILIPS#0 and remove the 4 screws
  4. Samsung Chromebook Plus Battery Replacement, Removing the battery: Schritt 4, Bild 1 von 1
    • Lift battery from bottom side first (marked with red line)
  5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: Schritt 5, Bild 1 von 1
    • Detach battery cable grabbing the side and pulling the cable upward.
  6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: Schritt 6, Bild 1 von 1
    • Insert the battery and push the plug into the socket downward.
  7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: Schritt 7, Bild 1 von 1
    • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: Schritt 8, Bild 1 von 1
    • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
Abschluss
To reassemble your device, skip steps 1-5.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Evan Elm
1.023 Reputation
3 Anleitungen geschrieben
Kid fixers Mitglied von Kid fixers
Community
156 Mitglieder
292 Anleitungen geschrieben
6 Kommentare
Great repair guide. Nice to see how easy it is to replace battery.
N ick - Antwort
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - Antwort
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
I managed to find a replacement part, see the parts section at the top of the guide :)
Evan Elm -
thanks for finding the battery part! Awesome job!
JT Cen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 50
Insgesamt: 6,817
