Einleitung
Use the guide below to replace the battery for the Samsung Chromebook Pro.
Was du brauchst
Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
Slide the plastic opening tool in a corner at a steep angle, and lift to remove the outer case.
Remove the four 30 mm screws surrounding the battery with the JIS J000 screw bit.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
