Einleitung
Follow the quick and easy guide below to replace the speaker for the Samsung Chromebook Pro.
Was du brauchst
Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
Slide the plastic opening tool in a corner at a steep angle, and lift up to remove the outer case.
Fast fertig!
Abschluss
