Einleitung
A quick guide on how to take off the bottom cover on your Chromebook. This procedure is a prerequisite for doing most repairs to your Chromebook.
Was du brauchst
Lay the Chromebook down so that the bottom cover is facing up.
Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
7 weitere Personen haben diese Anleitung absolviert.
