Einleitung
If your charger port is broken, this guide will teach you how to take apart your Chromebook and replace the faulty port.
Was du brauchst
Lay the Chromebook down so that the bottom cover is facing up.
Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
Remove the metal cover above the charging port module by pulling up and moving it slightly left.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
