Zum Hauptinhalt wechseln
Samsung Chromebook Series 3 Front Camera Replacement
Was du brauchst
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: Schritt 1, Bild 1 von 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: Schritt 1, Bild 2 von 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: Schritt 1, Bild 3 von 3
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook Series 3 Front Camera Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook Series 3 Front Camera Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: Schritt 3, Bild 1 von 3 Samsung Chromebook Series 3 Front Camera Replacement: Schritt 3, Bild 2 von 3 Samsung Chromebook Series 3 Front Camera Replacement: Schritt 3, Bild 3 von 3
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: Schritt 4, Bild 1 von 1
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: Schritt 5, Bild 1 von 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: Schritt 5, Bild 2 von 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: Schritt 5, Bild 3 von 3
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: Schritt 6, Bild 1 von 2 Samsung Chromebook Series 3 Front Camera Replacement: Schritt 6, Bild 2 von 2
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
Abschluss
Tyler Schultz
528 Reputation
3 Anleitungen geschrieben
IUPUI, Team S2-G1, Henning Spring 2019 Mitglied von IUPUI, Team S2-G1, Henning Spring 2019
IUPUI-HENNING-S19S2G1
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 392
