Was du brauchst
Lay the Chromebook down so that the bottom cover is facing up.
Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
Pull out the battery partway in order to easily get to the battery connector.
Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
Lift up the piece of tape covering the trackpad ribbon cable.
Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
Disconnect the trackpad ribbon cable by pulling it out.
Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
7 weitere Personen haben diese Anleitung absolviert.
