Einleitung
This guide will help you replace your RAM in your Chromebook by showing you step-by-step on how to remove it.
Was du brauchst
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Place the opening tool in the divot between the spine of the Chromebook and the back cover.
Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
Gently lift the bottom of the wifi card then pull it towards you to disconnect it from the socket.
Gently lift the top left corner of the RAM and pull upward to remove it from the Chromebook.
2 weitere Personen haben diese Anleitung absolviert.
