Einleitung
This guide will help you replace your speakers in your Chromebook by showing you step-by-step on how to remove it.
Was du brauchst
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Place the opening tool in the divot between the spine of the Chromebook and the back cover.
Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
Use a blunt precision tweezer to remove the speaker cord from the R.A.M.
Use the prying tool to find the divot then slowly add pressure until the speaker pops out.
Gently lift and remove the speaker from the Chromebook.
