Einleitung
Replace the back panel on a Chromebook XE550C22.
Was du brauchst
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
