Einleitung
After a period of time, the device might run too hot, this guide will help to clean up or replace the cooling fan for the Samsung Chromebook XE550C22.
Was du brauchst
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
Remove the four 3mm screws holding the battery with the J0 screwdriver.
Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
Locate the cooling fan and the heat sink on the top center of the Chromebook.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Rotate the Chromebook 180 degrees so the fan is closest to you, and locate the fan power cable.
Disconnect the fan cable from the motherboard with the angled tweezers.
Remove four identical 6mm screws from the heat sink labelled CPU using the J0 screwdriver.
Using your hands, gently lift up and pull away the heat sink.
Remove the three identical 6mm screws from around the fan using the J0 screwdriver.
Using your hands, gently lift up the fan and pull it away from the laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
